Guest garth05
Hello, my new home is fitted with an omnicron 8000 alarm and keypad. Unfortunately, the previous owners didn't leave a user manual. Does anyone know how i can get a user manual so as to change codes etc...
Thankyou
Posted (edited)
I'm just looking for a user manual.
Personally, I would just bin it and fit something else as the Omnicron is not held in very high regard tbh.
Edited by Lurch
Reset
Prog function
Existing code
1
New code
Reset reset
and if this fails try a large hammer :P
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
Guest garth05
yes, i am using the alarm now as i know the previous users' code. Would like to change though for peace of mind.
Guest garth05
thanks PJF - job sorted! Also, i have a remote keypad which is lit up but doesn't appear to respond to any key pressing. Any ideas would be appreciated. cheers
The RKPs for the omnicron are in my opion a pain, Only ever fitted one and could not get it to work, but luckily the customer sold the house before I got back to have another go.
If im correct the buttons are very stiff so have you tried pressing fairly hard(with a hammer). :P
Best thing for them, Its only a matter of time before it gives up or atleast the membrain wears out.
If I was garth 05 I would get it swapped now before he starts to decorate his new house, get a VR8 or simlar.
  • 12 years later...
