Guest Paul Posted October 6, 2005 Posted October 6, 2005 hi, my Optima XL6 keypad has stopped responding, the battery in the unit has not been changed for about three years. Do you think if I have a new battery fitted that this will resolve the problem? the backlight ,day and tamper lights are on but the keypad does not respond. thanks Paul
FASTCAR Posted October 6, 2005 Posted October 6, 2005 Hi Paul , If your tamper light is on , then you have a tamper fault , this could be the panel lid , the bellbox switch or any one of the sensing device covers or the wiring . Regards.
Guest Paul Posted October 6, 2005 Posted October 6, 2005 sorry it is the day and power light that is on and the backlight on the keypad, will I be able to open the unit without the alarm activating the strobe and siren?
Alarm Protection Posted October 7, 2005 Posted October 7, 2005 Opening the panel will set of a tamper. I would get an engineer to come out and do a service and have a look at you alarm at the same time.It will cost you(not a lot though) but your system will operate better. Take out a maintenance contract and get the system serviced once a year. !
