Accenta 6 + ADE Simple set
Guest whitcht
Guest whitcht
Is the ADE Simple Set RKP suitable for use with an Accenta 6 control box?
I've downloaded a PDF from a website although it doesn't specfically mention an Accenta 6 it does show a G3 which is similar i.e control box with 1 RKP which I have. I'm not going to exceed the 1A max load by adding this as I had a quick count up and am pulling about 475mA in total.
Regards
Tim Whitchurch
AFAIAA it just wires into the keypad line so should work with any recent ADE panel. ADE might be the people to speak to on this as I don't think that many here fit ADE equipment.
