Guest security.eng Posted October 15, 2005 Posted October 15, 2005 hi guys i am fitting a communicator to my galaxy 512 at home does anybody know which terminals are used for the tele line i have a,b,c,d,and bc being in the trade this was a rip out as was my panel hence no instructions but we only maintain 1 or 2 galaxys which were existing so have never fitted a comms mod on one of these, i mainly work on guardtec,texecom,scantronics, have no probs programming the panel but simple things !! any comments appreciated
Nova-Security Posted October 15, 2005 Posted October 15, 2005 Same as scantronic and the other panels yopu have worked on AB, if you stuck on that good luck on the programming. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest security.eng Posted October 15, 2005 Posted October 15, 2005 Same as scantronic and the other panels yopu have worked on AB, if you stuck on that good luck on the programming. thanks for that did suspect it could be but experience has taught me to ask if not sure! any idea what c,d and bc are for??
black knight Posted October 15, 2005 Posted October 15, 2005 thanks for that did suspect it could be but experience has taught me to ask if not sure!any idea what c,d and bc are for?? c d are for where you have a telephone handset connected to the the same point where you have connected your telephone line to. you connect the cabling going to handset to c d. bc is for the "ringer" connection i think but i could be wrong - terminal 4 i think on bt plug? paul THE BLACK KNIGHT "Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
Nova-Security Posted October 15, 2005 Posted October 15, 2005 c d are for where you have a telephone handset connected to the the same point where you have connected your telephone line to. you connect the cabling going to handset to c d.bc is for the "ringer" connection i think but i could be wrong - terminal 4 i think on bt plug? paul Ringer pin 3, the c d disconnect any of device connected to the phone line when the panel needs to make a call www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
whistle Posted October 15, 2005 Posted October 15, 2005 If your not sure how to conncet to coms mod god help you programing the thing.
