Guest grayfray Posted October 17, 2005 Posted October 17, 2005 Could I please have some phone numbers for installers covering the Skelmersdale area, looking for 6-8 pirs, possibly smoke detectors all connected to main panel connected to gsm autodialer. size of warehouse slightly bigger than football pitch. Thank you
jb-eye Posted October 17, 2005 Posted October 17, 2005 Could I please have some phone numbers for installers covering the Skelmersdale area, looking for 6-8 pirs, possibly smoke detectors all connected to main panel connected to gsm autodialer. size of warehouse slightly bigger than football pitch. Thank you Im in but only if its Proper Monitoring to a proper ARC. You can have auto dialer as well if you like.Jef Customers!
Nova-Security Posted October 17, 2005 Posted October 17, 2005 Im in but only if its Proper Monitoring to a proper ARC. You can have auto dialer as well if you like.Jef Well i would have said the same, but smoke detectors on a intruder is this possible under the new regs. www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Service Engineer Posted October 17, 2005 Posted October 17, 2005 6-8 Pirs doesnt seem much for a warehouse the size of a football pitch. Your gonna need more, Give Jef a call. And anyone else in your area who lists here. ........................................................ Dave Partridge (Romec Service Engineer)
Nova-Security Posted October 18, 2005 Posted October 18, 2005 Grade 3 Then www.nova-security.co.uk www.nsiapproved.co.uk No PMs please unless i know you or you are using this board with your proper name.
Guest G.J.M Posted October 21, 2005 Posted October 21, 2005 Well i would have said the same, but smoke detectors on a intruder is this possible under the new regs. if it's a building the size of a footy pitch then it's going to need a seperate fire system that with the fact that it will also come under fire precautions in the workplace act which by law will need a fire system. My personal opinion is that intruder should do intruder and fire should do fire not both on anything bigger than a small house,although if a house up here is bigger then 2000m2,it needs a part 1 fire system.Usually L3.
