Scantronic 9452
Guest Alan
Dear All
I have a Scantronic 9452 panel that no one has the programmed access code for.
The installer is no longer in existence and the previous house owners have no idea what the code was (never used the system)
Can anybody let me know how I go about resetting the system to factory settings and what the default access code is.
Thanks in advance
Alan
The system can be deafulted but it will need to be reprogrammed and set up correctly to suit your needs. The batteries will also need to be checked.
I would try 1234 or 5678 to see if they work first.
I would reccomend that you get a local installer to do this work for you, if you let us know what part of the country you are in then one the guys should be able to assist you further.
Colin.
Guest h.s.ouwehand
Alan,
I found this in my 'security library'":
<<REMOVED FOR SECURITY REASONS>>
default codes
engineer 7890
user 1234
Success
Bas
Pete/Alan,
I have removed details on how to default this panel.
Please do not post details on how to default panels in public forums, only in the "Panel Defaulting" in the secure area.
As it compromises the security of systems, and could get us into trouble legally.
Many Thanks
Dale (Moderator)
Dale
