Heat Detectors?
Guest Rocky
Ruling out naked flames, Jamie Oliver style blow torch mania and waving soldering irons about the place, how do you safely walk test an heat detector?
I use aerosol smoke for testing smoke detectors, but I'm a little scuppered when it comes to testing a heat detector.
I'm also led to believe there are two types of heat detector (if not more), one detects a pre-fixed temperature and the other detects a rapid rise in temperature.
Any info out there?
I use a hair dryer (admitedly I get strange looks from customers, but I have great looking hair)
D
:huh: there is a special tool made by solo it comes with charger and two batteries but it is expensive around the £200 mark
if your allowed to use 240vac equipement a hair drier will do
but keep a distance of a 30cms from the detector
don't use blow torch of paint stipper heat gun they are two hot and will damage detector (will work this visit and will not the next) also it tends to melt the plastic
there are 3 common types rate of rise(looking for sudden temp changes) these test quickly fixed temp type 1 (around 55-60 c) and type 3 (around 90 c fixed)
these take a bit longer to test but dont be tempted to get the hair drier any closer
just a word of warning some older heat detector pre 1988 were 1 hit wonders
and after one use you replaced :blink: they look like a small 10p sized disk hanging from celing and ave no led indication
most of the plastic type are ok
good luck B)
Thanks chaps, looks like put a hair dryer on my Xmas list, Should I get one with a defuser? :D
Guest andy jinks
its the pink Barbie hair dryer everytime for me
