Optima 2 plus fault
Guest 2202
My Optima 2 has suddenly developed a fault on zone 1...front door contact and keeps on bleeping when the door opens. The figure 1 appears on the panel but can be dismissed by a reset. However when the door is opened again the bleep is triggered again and we are back to the cycle start again.
Any Ideas
You have enabled the CHIME feature:
TO CHIME A ZONE
The Day indicator should be showing. Press the CHIME button, the Day indicator will go off. Enter the
zone number(s), which you require to be chimed, or if you wish to cancel a previous selection enter 0.
The system will automatically return to Day after a few seconds. When any zone chosen to be chimed is opened or closed the sounder will produce a series of tones and indicate the zone number Press RESET to remove this indication. To cancel a chime selection, press CHIME and enter 0. The system will return to Day after a few seconds.
Many thanks.
It appears to have worked.
The pdf has been archived away.
A number of electrical items in the house appear to behaving unusually since a nearby lightning strike.
regards
Tony
  • 1 month later...
Guest Roger Allen
TO CHIME A ZONE
Guest Roger Allen
TO CHIME A ZONE
Thanks also from Roger Allen - or 11 month grandson had enabled the chime feature.
Roger
  • 1 year later...
can you help !! i have an optima 2 plus alarm, it won't activate as its showing zone 3 and beeping non stop till i enter the code again.......... thanks
Need more info. What do you mean by activate? do you mean set? if so, go check what device is on zone 3. its causing the problem. are there any other L.E.D's on that are not usually?
once you establish what is on zone 3 make sure it has not been touched, moved(decorators, carpet fitters), opened(is the device on a door/window?), pressed(panic button).
Had any workmen in, done any decorating, nosey grandchildren, burglars?
Doesn't that mean a fault or alarm on Zone 3?
What does your user manual say (remember there may be different types/patterns of beeps)?
What type of sensor is zone 3?
