Guest etd139 Posted October 22, 2005 Posted October 22, 2005 Hello i have a Nexus 8 alarm system and the bellbox has failed so i bought a new one . The new bellbox is a Aritech AS610 but i cant wire it up. i have the instructions for the alarm control panel and for the new bellbox but i cant still work it out . please help Edward
Mister_Dave Posted October 22, 2005 Posted October 22, 2005 Post the terminals of the bellbox and the panel and i will try and work it out. Dave Oxendale York based security systems engineer.
Guest etd139 Posted October 22, 2005 Posted October 22, 2005 Post the terminals of the bellbox and the panel and i will try and work it out. hi Dave see what you can do please regards Edward
Service Engineer Posted October 22, 2005 Posted October 22, 2005 Bellbox-/-Panel 1--/--STR 2--/--TRG 3--/--HOLD+ 4--/--HOLD- 5--/--HOLD- ,(or could just be linked to 4 directly in the bellbox). 6--/--TPR You will probably have to cut some jumpers to configure the bell ring duration: (J1= 5 Mins), (J2=10 Mins) & (J1 & J2 for 20 mins), and probably J4 & J6 to enable the 0 volt triggering of Sounder and strobe. You may also have to wire in the 2x 1K resistors as shown on the diagram. One from 1 to 3, the other from 2 to 3. ........................................................ Dave Partridge (Romec Service Engineer)
