DVR network Question
jizzer
Hello,
I want to network One dvr to one pc Domestic)Can this be done simply via a crossover lead as you would if you wanted to connect two pc's or does it have to go through a router etc.
From a networking point of view you should only need a networking cable. As many LAN cards autosense you might not even need a crossover, just a standard cable. That's assuming you've manually configured both IP addresses, etc and aren't depending on a router to do that for you.
As lurch, cross over needed unless you have a Hub / Switch or a router with spare ports.
www.nova-security.co.uk
www.nsiapproved.co.uk
Guest Rockford
Incorrect. IEEE standard 802.3 (ethernet) defines that workstation NICs are not to autosense when using twisted pair. If they did, you'd confuse your autosensing network switches. There are a couple which break standard, but DON'T use them because without adhering to standards, there's absolutely no garantee that they'll work at all. You will need either a hub/switch OR a crossover cable. A straight network cable will not work. Crossover wire map (catagory 5e, RJ-45): switch pairs 1-2 with 3-6 (1=white/orange 2=orange 3=white/green 6=green).
I did only say it "might" work with a standard cable. :rolleyes:
Crossover is of course the recommended cable.
