paul fae kings Posted November 5, 2003 Posted November 5, 2003 Went to a large shop on a retail park today to take the system over.Just run of the mill stuff i thought opens the panel and nearly got blinded by the heat. The system is only 9 months old,but it turns out that since day one,the main pcb has been punting out 20.11 volts dc.Surely not ithought,but apparently so.Also couldnt find any meter readings,the amazing thing is though that it has worked perfectly for so long. I swear the battery was so hot you could hardly touch it,and was still toasty an hour later. Anyhow just thought i'd share that one with you Strange but true
Service Engineer Posted November 6, 2003 Posted November 6, 2003 Hope you changed the panel..? ........................................................ Dave Partridge (Romec Service Engineer)
Guest andy jinks Posted November 6, 2003 Posted November 6, 2003 we used to use powersonic batts and you often found them hot charging at 13.8. it was nice in the winter but not for the alarm. Dave does that powersonic batt still take pribe of place in the 800 on th front page ?
Service Engineer Posted November 6, 2003 Posted November 6, 2003 No mate, we had a faulty batch of Powersonics about 6 years ago, so i used my initiative and removed the one from my own panel. There`s a nice 7AH Yuasa fitted now. ........................................................ Dave Partridge (Romec Service Engineer)
paul fae kings Posted November 6, 2003 Author Posted November 6, 2003 The technical support guy thought i was having a laugh,he'll find out i wasnt though when the pcb arrives on his desk
Guest andy jinks Posted November 7, 2003 Posted November 7, 2003 what was that panel that had a sticky foot stuck in the bottom of the panel to lift the batt out of the way of the screw hole.........
Guest andy jinks Posted November 21, 2003 Posted November 21, 2003 Was it an old castle panel (omega 8,control 4) still thinking 2 weeks on... P.S This is my 100th post do i get a badge or something ?.........
Guest oldtimer Posted November 21, 2003 Posted November 21, 2003 I had the exact same problem about 2 years ago with a Optima 2+ I phoned ADE and they said the voltage regulator on the panel was faulty and they said to check out any equipment that draws power from the panel. I eventually traced the problem to a compfort LED that was fitted to the bottom of an old H type bellbox.
