Guest Zark Posted October 25, 2005 Share Posted October 25, 2005 I manage a sleep lab in the United States. We have several Sony SSC-E473 SuperExwave color cameras that work OK except that I need them to switch to night mode at higher light levels (dim incandescent) than their programming will allow. I am using IR lights. The cameras are being used to record medical procedures. The manufacturer's instruction sheet is unclear, at least to me, on how to hook up the external day/night trigger control. Here is what it says: Pin #1: External Control Output. Outputs the color/B&W switching signal. Pin #2: COM. Ground for External Control In/Out. Pin #3: External Control Input. (Accepts high impedance signal only.) When H (+5V) is applied between this terminal and COM, color mode is selected. When L (0V) is applied, B&W is selected. Have any of you used this camera or ones similar and hooked up the external trigger to switch between day/night modes? Any insight on how to get this working is much appreciated. Thanks Zark Link to comment https://www.thesecurityinstaller.co.uk/community/topic/7944-how-to-wire-external-trigger-on-daynight-mode/ Share on other sites More sharing options...
Rich Posted October 25, 2005 Share Posted October 25, 2005 Hi Zark What are you using for the Day/Night trigger? You need to know the 3 conections of the day night trigger you are using. Basically, it sounds like your external trigger will supply 0 volts between pins 2 and 3 for B&W operation, then it will supply +5 volts to switch the camera to colour mode. Pin 1 sounds like its the signal telling the external trigger what state the camera is currently in. Do you have information on the external trigger? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/7944-how-to-wire-external-trigger-on-daynight-mode/#findComment-73360 Share on other sites More sharing options...
