Abacus 8
Guest Rocky
On the Abacus 8 system...
If the 'Push To Set' button is pressed whilst the exit device (in this case a C100 dualtech) is still active (with the internal sounder emitting a bleeping tone to indicate an open zone as expected), does the system register a bad set?
A client is experiencing bad set problems but I suspect they are not allowing enough time for the detectors to close out (i.e. they're not waiting for the internal sounder to emit a constant tone) before they're pressing the 'Push To Set'.
What do ya think?
Im not too familliar with the Abacus 8, but cant you enable a setting delay to overcome the problem..?
