Guest bert Posted October 28, 2005 Posted October 28, 2005 Anyone reccomend a good PAT tester doesnt have to be the cheapest in the world but needs to be reliable, easy to use and accurate. Thanks
BUSTER Posted October 29, 2005 Posted October 29, 2005 We use the AVO/Megger Pat 4DV with Powersuite software. Had it for 4 years without any problem Any comments / opinions posted are my opinion only and do not represent those of my employer or Company
ian.cant Posted October 29, 2005 Posted October 29, 2005 Anyone reccomend a good PAT tester doesnt have to be the cheapest in the world but needs to be reliable, easy to use and accurate.Thanks Put two shovels in a room and ask Pat to take his pick
Stealth Posted October 29, 2005 Posted October 29, 2005 We use the AVO/Megger Pat 4DV with Powersuite software. Had it for 4 years without any problem Ditto that, simple to use, takes all the readings for you. Chubb Service Engineer
Mavrick_001 Posted October 30, 2005 Posted October 30, 2005 PAT4DVF here great tester CCTV Intruder Access Control Tony Hughes, Proprietor, TRADE MEMBER
Billy@Solutions4CCTV.com Posted August 4, 2006 Posted August 4, 2006 Check out http://www.seaward.co.uk/ If you need to buy one let me know cos my mate owns a company in Newcastle Staffs who will sort you out. Make sure you get one that records results and downloads, they are better than a quick 'press to test' type that just gives a green light ! Hope that helps Billy Solutions4CCTV Keeping an eye on your property
