Geovision GV600
The Arab
Has anyone come accross this strange problem with geovision.When you go to view images in log the in single picture option the picture is double but is in a very 70s top of the pops type blur and only shows green and purple but if you ask for quad or multi it only shows 3 of the 4 or 8 cameras available.But when you record the weirdness to cd piture is okay.
I tried swapping from ntl to the other option but it then make all pictures black and white i am sure i'm missing something obvious. :no::cry:
Trade Member
I know on the GV-250 you get the green & purple colours if you mix mono & colour cams. Geovision say you cannot have equal to or more colour cams than mono ones, although I have found on mine that mixing them in any configuration gives you the psycadellic colours.
Trade Full Member
Yes it does have pal and ntsc if it's on ntsc it goes black and white and all cameras are colour :!:
Trade Member
Not had any colour problems but found when burning recordings to cd the picture tends to try to keep buffering, although viewing recorded images direct from the DVR are fine.
cheers Kev
