LeonThePro Posted November 1, 2005 Share Posted November 1, 2005 Basically I am thinking of putting in some CCTV at my house and think it would be good learning experience for me to understand more about how the whole systems works and is put together. Having read through Part P regs I am slightly confused. Does the install of camera come under Part P? As your laying electrical cable to power it I would then have to put in a PSU. So am I right in saying that plug in PSU would notcome under Part P as longer as it goes to an existing sockect but a box PSU would come under Part P? Damn I confusing myself again. Thanks for any guidance. Link to comment Share on other sites More sharing options...
Guest Posted November 2, 2005 Share Posted November 2, 2005 Basically, if it's on a plug then it doesn't come under part P. As a rough rule of thumb(ish) - if it is wired in via a spur it may come in depending how you wire the spur up and where you site it. If it's in a kitchen or bathroom, or supplied from a new circuit, it's in the scope of part P. If it's just in the loft and connected to a spur from the ring that you fitted then it's not in the scope of part P. Link to comment Share on other sites More sharing options...
ian.cant Posted November 2, 2005 Share Posted November 2, 2005 Just a point to note, Part P is enforced by.............................................. The DIY police? Link to comment Share on other sites More sharing options...
Guest Gti Jazz Blue Posted November 9, 2005 Share Posted November 9, 2005 So glad I've got about 40 metres of the old type 2.5mm T&E in the garage. Part P - overkill again - red tape. So how many people are killed by dodgy electrics compared to on our roads by bad driving ? Had a rather interesting chat with my local building regs department and all I could hear was him frantically scanning paper as I asked questions about what it restricted by Part P. Also he couldn't answer all of my senarios that I put to him, he said off the record that most of them are cheesed off by having to deal with Part P as they had joined up to inspect building work not be Electricians. Link to comment Share on other sites More sharing options...
Guest Posted November 9, 2005 Share Posted November 9, 2005 So glad I've got about 40 metres of the old type 2.5mm T&E in the garage. Doesn't mean anything, I've been using harmonised coulours since the beginning of last year. Link to comment Share on other sites More sharing options...
Guest Gti Jazz Blue Posted November 9, 2005 Share Posted November 9, 2005 Doesn't mean anything, I've been using harmonised coulours since the beginning of last year. Black and Red = Cable was original and installed before Part P requirements Link to comment Share on other sites More sharing options...
Guest Posted November 9, 2005 Share Posted November 9, 2005 Black and Red = Cable was original and installed before Part P requirements Why bother, red and black is now against BS7671 and has been since 1st Jan\1st Apr depending on where you're installing it and in my case (along with thousands of others), brown and blue = installed before part P requirements. Link to comment Share on other sites More sharing options...
Guest IM_Alarms Posted November 23, 2005 Share Posted November 23, 2005 Useful little basic guide to Part P requirement here:-http://www.niceic.org.uk/partp/does_partp_apply.html Hmmm don't you mean basic advert for NICEIC Link to comment Share on other sites More sharing options...
Guest Posted November 23, 2005 Share Posted November 23, 2005 Hmmm don't you mean basic advert for NICEIC There are, I believe, 13 domestic installer schemes running. Link to comment Share on other sites More sharing options...
