Guest ukchik33 Posted November 3, 2005 Posted November 3, 2005 Hi just moved into new house. Above alarm installed. Not got previous owner's pin code. Need to reset alarm. Can anyone please help. It would be much appreciated thanks.
ian.cant Posted November 3, 2005 Posted November 3, 2005 You will need an engineer to default the panel for you, even with the user guide you still wont be able to do anything without a useable code. Check this list HERE and you should find someone local to you. On this thread here you will find the USER GUIDE.
