optima XL4 problem
Guest stanman
Guest stanman
Hello All
I have a Optima XL4 fitted in my house, its been here since I moved in (5 years). It has the usuall Window sensors and 2 panic alarms.
Proplem is that lately i've come home and its been triggered by something. And now, even worse a couple of times its gone off while i've been in and its not even been set.
Could it be a dodgey panic botton? there the type with the large red botton and a small key in them.
cheers if anyone can help.
Stan
More likely it's a Tamper fault. Could be a loose connection or damaged cable anywhere on the system.
Get it Serviced by an engineer and I would reckon that the battery has not been changed in the last 5 years.
Hello All
Stan
5 years is a long time, if your alarm has not being looked at by a engineer. best advice is to get it checked over by a pro. :)
Probably your outside siren tamper has corroded/ corroding.. Does it sound both internally and externally or just internally??
