Smart Electrics Posted November 9, 2005 Posted November 9, 2005 Alsec do a speed test and let us know if you are getting a good speed try the following link. It is a good test point. http://www.auditmypc.com/internet-speed-test.asp. I would say personaly that the router is not to blame but it does sound like a line problem.
Guest Posted November 9, 2005 Posted November 9, 2005 I would say personaly that the router is not to blame but it does sound like a line problem. I personally would say if the wireless is dropping out intermittently too it could well be the router, of course, wireless does drop out from time to time on mine and the laptop and AP are only a few feet apart.
Smart Electrics Posted November 9, 2005 Posted November 9, 2005 I personally would say if the wireless is dropping out intermittently too it could well be the router, of course, wireless does drop out from time to time on mine and the laptop and AP are only a few feet apart. Is it wireless then
Smart Electrics Posted November 9, 2005 Posted November 9, 2005 I personally would say if the wireless is dropping out intermittently too it could well be the router, of course, wireless does drop out from time to time on mine and the laptop and AP are only a few feet apart. Just going by what you said chapy
Paul P Posted June 20, 2006 Posted June 20, 2006 Getting back to the original problem, my mate has been having hassle with his broadband since Christmas if you plug the router to the master socket without any front plate or internal wiring connected all is OK. If you connect a wire that goes up the wall to the first floor bedroom it drops out. The wire is only 2-3m long ran near no mains so what can be wrong with it, even rewired it and still it drops out. Connect the rest of the house and no way will it work. Any Ideas plus are there any other ways us mortals can test ADSL signal? Regards Paul PS the house is a long way from the exchange. Trade Member
Guest ALSEC Posted June 20, 2006 Posted June 20, 2006 Getting back to the original problem, my mate has been having hassle with his broadband since Christmas if you plug the router to the master socket without any front plate or internal wiring connected all is OK. If you connect a wire that goes up the wall to the first floor bedroom it drops out. The wire is only 2-3m long ran near no mains so what can be wrong with it, even rewired it and still it drops out. Connect the rest of the house and no way will it work.Any Ideas plus are there any other ways us mortals can test ADSL signal? Regards Paul PS the house is a long way from the exchange. I think most routers will give you signal details of the ADSL but what it all means is a differnet story - maybe some internet forum may be able to help - maybe even have an engineers manual??? Is something else on the internal wiring dragging it all down? What about if you connect router to master socket on fly lead which you know is 100% - maybe that extra 2m is just too much
Service Engineer Posted June 20, 2006 Posted June 20, 2006 The wire is only 2-3m long ran near no mains so what can be wrong with it Bad connection. Poor/incorrect/intermittant termination. Hi-Res cable. Damaged/punctured cable. Cable cores shorting on carpet gripper. ........................................................ Dave Partridge (Romec Service Engineer)
arfur mo Posted June 20, 2006 Posted June 20, 2006 Getting back to the original problem, my mate has been having hassle with his broadband since Christmas if you plug the router to the master socket without any front plate or internal wiring connected all is OK. If you connect a wire that goes up the wall to the first floor bedroom it drops out. The wire is only 2-3m long ran near no mains so what can be wrong with it, even rewired it and still it drops out. Connect the rest of the house and no way will it work.Any Ideas plus are there any other ways us mortals can test ADSL signal? Regards Paul PS the house is a long way from the exchange. hi paul, do you not need an adsl filter at each socket and connect handset vis it? i did this for a mate and it solved problems of interner dropping out on phone calls. regs alan If you think education is difficult, try being stupid!!!!
ranger Posted June 20, 2006 Posted June 20, 2006 Now we are going back to basics Ranger The above is my personal opinion and not that of my employer or anyone else.
