Guest wazza Posted November 8, 2005 Posted November 8, 2005 Hi, i have a eurosec cp8l alarm system. The entry point is set for the front door where there is a time period for you to key in the code. If we enter through the back door the alarm is triggered straight away. Is there a way to add the back enterance to the alarm system?
advancedprotection Posted November 8, 2005 Posted November 8, 2005 do you have the engineers code for the system? if not you need to contact the company who installed the system for you to re-program the zone attributes for you. hope this helps. Martin Trade Member It's nice to be important but it's more important to be nice!! Martin Hanfo CCTV - Intruder Alarms - Access Control - Security Lighting - Locks Covering South Wales 07903 967045
Guest Posted November 8, 2005 Posted November 8, 2005 you need to contact the company who installed the system for you to re-program the zone attributes for you. Or any competent company if they are not available for some reason.
