CCTV Maintaince
Guest GeorgeN
Guest GeorgeN
Hi all. I've been installing/maintaining alarms for nine years and I
Cameras,
Lenses correctly set and secure
Brackets fully secure
Connections properly made and correct
lenses and glass clear from obstuctions (dirt)
And clean housings/camera.
DVR
Time correct
Functions set up correctly
Cables and connections secure and correct.
Clean
VCR
Clean heads and tape path.
Service to VCR
Check connections.
Clean
Secure boxes.
Check lock
Clean
Monitors
Check cables and connections
Check settings
Clean
Cables, check all connections are properly terminated and cable is not damaged.
Thats the basics
Richie due to your excessive workload you missed........
Check recordings/ playback :bruce_h4h:
Ah yes, was just checking you was awake ian, well done, here's a chocolate star..*...fish
:P
:P
No thanks, i lurve chocolate but im not that type of soldier..............
