Menvier TS700 Lid Tamper problem
Guest RDS Mike
Guest RDS Mike
Hi
Servicing an old TS700 and the RKP (starburst) suggests a continuous 'lid tamper' on the CP - switch is working devlivering 5 volts to the output when switched. All appears neat, clean and okay and manual gives no indication - can you?
cheers
Hi
cheers
Had similar on a TS2500 Networker. Try Closing the panel, and keeping it closed for at least 2 minutes before exiting the engineers menu. If it still shows panel tamper, go back into engineering, wait another 2 minutes and then exit again. Should be OK, otherwise you have a hardware problem.
Lt or lid tamper on a ts700 can be bell tamper as well as panel lid.
No thats aux tamper
Mark Hawks
Ex BT Openreach Field Service
Guest RDS Mike
Thanks Guys
Should have said that the aux tamper has been strapped.
Tried the suggestion of DeltaSeven but still got hte tamper warning _ should I presume that the CP is down then? Anyway to bypass this so the CP can be still of some use!!!!?
Many thanks again
Guest RDS Mike
Thanks Guys - problem solved!
The ts700 does infact share its lid tamper with the bell tamper cct (possibly the aux tamper as well thou have not tested that) -a problem with the bell tamper cct will show as a lid tamper problem on the RKP.
Thanks again
What was that you were saying Mont :sothere:
Ok i was wrong, long time since i work on a ts700 :fear:
Mark Hawks
You are forgiven my friend
Guest RDS Mike
Now now no arguing guys!!! I appreciate both your help - thanks again.
