Guest SUZY01 Posted November 12, 2005 Posted November 12, 2005 We have just had to purchase a new bell due to our previous unknown bell packing up. We have purchased the Vortex bell box by Lynteck and are trying to install this unit to a Pyronix Octagon alarm panel that has an RKP contral panel attached and SD1 Speech dialler also attached. We have entered engineer mode and wired the bell as follows: Alarm Panel Bell BA TG- S+ Hold + -B Hold - BT Return STB STB- The alarm then sounded for 5 secs as the jumper was in the position for 5 secs then stopped but the lights are continuning to flash indicating bell trigger action. We then tryed bell test mode in engineer mode but nothing. We then tryed to set our alarm to see if the leds would change but still flash as triggered. Any Ideas? Thank you
Monteey Posted November 12, 2005 Posted November 12, 2005 This i think you'll find is a feature of the bellbox and is a deterrant to wouldbe intruders to prove the bell is real, the only way you'd be able to switch them off is to cut them off the actually bell, if you look at a lot of modern boxes you will see LED's flashing all the time. This does not mean the alarm has triggered. The way you've wired it is correct and i assume the bell is sounding once you trigger it On looking at the instructions it seems i may be mistaken, not sure quite what bell trigger activation actually means, but the sensible thing to do would be to remove the TG- connection from your panel and see if the LED's go to normal status, that will prove if the panel is triggering the bell or not Mark Hawks Ex BT Openreach Field Service Now Self employed telecom and data engineer www.mphtelecom.co.uk Also back doing sub contract work in the security industry. Retained firefighter Devon and Somerset Fire and Rescue
Guest SUZY01 Posted November 13, 2005 Posted November 13, 2005 This i think you'll find is a feature of the bellbox and is a deterrant to wouldbe intruders to prove the bell is real, the only way you'd be able to switch them off is to cut them off the actually bell, if you look at a lot of modern boxes you will see LED's flashing all the time. This does not mean the alarm has triggered.The way you've wired it is correct and i assume the bell is sounding once you trigger it On looking at the instructions it seems i may be mistaken, not sure quite what bell trigger activation actually means, but the sensible thing to do would be to remove the TG- connection from your panel and see if the LED's go to normal status, that will prove if the panel is triggering the bell or not Will try removeing the connection you mentioned but currently we can not get the bell to work when doing an engineers bell test. The manual for the box shows different led flashes for what mode the bell is in but it is not flashing as alarm not armed as it should it is flashing as if the alarm had been set off but with no sound.
Guest SUZY01 Posted November 13, 2005 Posted November 13, 2005 Will try removeing the connection you mentioned but currently we can not get the bell to work when doing an engineers bell test. The manual for the box shows different led flashes for what mode the bell is in but it is not flashing as alarm not armed as it should it is flashing as if the alarm had been set off but with no sound. The box is making no sound when alarm is set off
Adi Posted November 13, 2005 Posted November 13, 2005 What connections have you got on the sounder? I really can't be ar**** with it anymore.
Guest SUZY01 Posted November 13, 2005 Posted November 13, 2005 What connections have you got on the sounder? As mentioned above, these are the only connections.
Adi Posted November 13, 2005 Posted November 13, 2005 Have you tried swapping around TG- and return? I really can't be ar**** with it anymore.
Guest KRISS CROSS Posted November 26, 2005 Posted November 26, 2005 using a volt meter find the permanent live and neutral connect them to there respective holds find too switched negatives when in alarmed condition using the perminant live one is switched neg for bell the other is the strobe the one left is the tamper hope this helps by the way the leds do fash all the time so that no one knows if its armed or not.
Guest Posted November 26, 2005 Posted November 26, 2005 You want to get your live\neutral and positive\negative looked at Mr Cross. One is AC, one is DC.
Guest KRISS CROSS Posted November 26, 2005 Posted November 26, 2005 You want to get your live\neutral and positive\negative looked at Mr Cross. One is AC, one is DC. not on my meter H+ and H- Doesn't imply ac otherwise it would be nither neg or poss point taken were i have said live i should have said positive and were i said neutral i should have said negative arn't we the padantic one anyway i hope this helps.
