Guest Gerry J Posted November 15, 2005 Posted November 15, 2005 I wish to install either a ESP Infinite or a Texecom Premier 24 alarm system. I will need 5 PIR's and a magnetic switch. I would also like the alarm to notify on my mobile phone if the system goes off. Any comments please?
Adi Posted November 15, 2005 Posted November 15, 2005 Well do you want to install a wireless system or a hard wired? I really can't be ar**** with it anymore.
Guest Gerry J Posted November 15, 2005 Posted November 15, 2005 Well do you want to install a wireless system or a hard wired? I don't mind which I install, it is just that these two systems seem to fulfil my requirements.
Alarm Protection Posted November 15, 2005 Posted November 15, 2005 But is it wireless or hardwired? !
dpaengineer Posted November 15, 2005 Posted November 15, 2005 If you don't mind doing either, then go for hard wired. Much better in the long run. Trade Member
Adi Posted November 15, 2005 Posted November 15, 2005 Prem 24 it is then. Ive got one on my house its a good panel i fitted an infinite a couple of weeks ago and wouldnt rate it anywhere as good as a prem 24 i know there are different technologies but the infinite just lacks programming and few other options. Go with a 24, if you installed an infinite you would probably end up wishing you had installed a 24 it has a lot more to offer. I really can't be ar**** with it anymore.
dpaengineer Posted November 15, 2005 Posted November 15, 2005 Prem 24 it is then. Ive got one on my house its a good panel i fitted an infinite a couple of weeks ago and wouldnt rate it anywhere as good as a prem 24 i know there are different technologies but the infinite just lacks programming and few other options.Go with a 24, if you installed an infinite you would probably end up wishing you had installed a 24 it has a lot more to offer. QFA. I have a Prem 816, Not quite the same as the 24 but along the same lines. I wish i'd gone for the 48. Depends where your budget lies though I guess. Trade Member
Adi Posted November 15, 2005 Posted November 15, 2005 True but if you dont need areas a 24 will do. I really can't be ar**** with it anymore.
