Guest Patrick Woo Posted November 18, 2005 Share Posted November 18, 2005 hi,we want to release some new design on IFSEC 2006, and not have a good idea on which security cameras are popular in european market, anyone of you can give an idea, also we have camera available in our website, can anyone give some suggestion on how to improve the design,tks www.wanjiaan.com/en Link to comment Share on other sites More sharing options...
Rich Posted November 18, 2005 Share Posted November 18, 2005 If you want to design something that is different, then solve the problem of the nightvision cameras with built in led's that are intended for external use. The problem being cobwebs. Also the ir's should be more flood than spotlight. Link to comment Share on other sites More sharing options...
Guest Patrick Woo Posted November 19, 2005 Share Posted November 19, 2005 If you want to design something that is different, then solve the problem of the nightvision cameras with built in led's that are intended for external use. The problem being cobwebs.Also the ir's should be more flood than spotlight. thanks,rich,i agree with u, doing night vision camera w/ led inside is easy, however,we not clear your meaning "the IR's should be more flood than spotlight", can you explain it, by the way,do u have any good idea on zoom camera, now we have 16x,22x,27x zoom camera built-in auto iris lens, anyone of you have any suggestion on it ? we hope to develop and release on IFSEC 2006. MSN:wsw203@hotmail.com Link to comment Share on other sites More sharing options...
Rich Posted November 19, 2005 Share Posted November 19, 2005 thanks,rich,i agree with u, doing night vision camera w/ led inside is easy, however,we not clear your meaning "the IR's should be more flood than spotlight", can you explain it,by the way,do u have any good idea on zoom camera, now we have 16x,22x,27x zoom camera built-in auto iris lens, anyone of you have any suggestion on it ? we hope to develop and release on IFSEC 2006. MSN:wsw203@hotmail.com Well, it would be better to have the light emitted less circular and like a torch/spotlight and instead actually illuminate the same area of view as the camera more like a flood. I will be wanting some freebies for this, so make sure you have some examples I can take away with me Link to comment Share on other sites More sharing options...
ian.cant Posted November 19, 2005 Share Posted November 19, 2005 Yes agree with Rich on this one, the width of the illumination area could be better. Usually illuminated range is 10 mtrs, that is distance from the camera but the width of the illuminated area may only be 2 mtrs but the image is 15 mtrs wide. Link to comment Share on other sites More sharing options...
Guest Posted November 19, 2005 Share Posted November 19, 2005 Yes agree with Rich on this one, the width of the illumination area could be better. Usually illuminated range is 10 mtrs, that is distance from the camera but the width of the illuminated area may only be 2 mtrs but the image is 15 mtrs wide. Well you get what you pay for.. Get some IR ILLUMINATORS and your problems are solved (as you propably know).. I can supply you with those if you want. Thou price is something else than Link to comment Share on other sites More sharing options...
