PJF Posted November 22, 2005 Posted November 22, 2005 Welcome mate, you trying to rub it in with the sunglasses. Its a bit cold over here Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
Guest Peter James Posted November 22, 2005 Posted November 22, 2005 ευπρόσδεκτοσ, να ο τόποσ συζητήσεωσ Pete
Smart Electrics Posted November 22, 2005 Posted November 22, 2005 Multi mongrel then Pete i like it . Wellcome to the forum
Guest IM_Alarms Posted November 23, 2005 Posted November 23, 2005 B) Hi Jami!! Your last name wouldn't be ''Bugger'' would it?
Guest jami Posted November 26, 2005 Posted November 26, 2005 It's just November and the sun still shines in Greece guys!!Sunglasses are still neccesary!!Visit Greece and call me a liar!!!Έχει πλάκα να βρίσκεις συμπατριώτες στο Forum!!!
Guest Peter James Posted November 26, 2005 Posted November 26, 2005 Όχι όλα είναι όπως αυτό apears στο διαδίκτυο Pete
Guest jami Posted November 26, 2005 Posted November 26, 2005 Όχι όλα είναι όπως αυτό apears στο διαδίκτυοPete Δεν κατάλαβα..Τι εννοείς;
