Guest davidbanner Posted November 25, 2005 Posted November 25, 2005 I moved into a new house with veritas 8c alarm fitted. pre 2000 it was connected on the fuse board to some lights . Whilst away my father in law blew the lights which has killed the alarm. battery and fuses removed. i have purchased a new battery and fitted it. and replaced the fuses all seems good except when i press code part it doesnt do the zones i want so i press omit and set the zones i want and its fine and works ok but the next time i come to set it its the same and has reverted back to other settings how can i get the zones to stay programmed into the full/part memory to stop me having to programme it every time? also i cannot walk test the alarm any ideas much appreciated i live in Cheshire in the Wirral area btw
morph Posted November 25, 2005 Posted November 25, 2005 Sounds as though the system needs the engineer programming redone to suit your needs. I would suggest that you get a local installer in to do this.
