kka Posted November 26, 2005 Posted November 26, 2005 what is the most affective way to alarm a roller shutter Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest Peter James Posted November 26, 2005 Posted November 26, 2005 How about a roller shutter contact??
Guest IM_Alarms Posted November 26, 2005 Posted November 26, 2005 what is the most affective way to alarm a roller shutter Or tell it that it's about to get ram raided!!
norman Posted November 26, 2005 Posted November 26, 2005 Arf. Nothing is foolproof to a sufficiently talented fool.
morph Posted November 26, 2005 Posted November 26, 2005 We generally use Heavy Duty Contacts, follow this link and it will tell you a bit more about it, the interconnecting cables are also protected by aluminium tube down the side of the shutter. http://www.oslgroup.com/UploadedFiles/8/7/...39063362500.pdf
hastings Posted November 26, 2005 Posted November 26, 2005 Brick it up !! Or roller shutter contact on both sides if door is wider than 7 or 8 foot, always a dual tec inside as well.
kka Posted November 26, 2005 Author Posted November 26, 2005 Brick it up !!Or roller shutter contact on both sides if door is wider than 7 or 8 foot, always a dual tec inside as well. thanks lads, good advice with a bit of humour thrown in free. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest IM_Alarms Posted November 26, 2005 Posted November 26, 2005 thanks lads, good advice with a bit of humour thrown in free. Wait till you see the invoice!!
cymruchris Posted November 27, 2005 Posted November 27, 2005 I'd agree with all the above... from my experience investigating burglaries and ram-raids - I'd make sure that any shutters over 6ft-7ft wide have a contact on both sides..... I've seen a few roller shutters levered up on the opposite side to the contact - which as a resut failed to trigger the alarm... Covered PIR's didn't help either...
