Adding a Sound Bomb
djrock
Hello, I was thinking of connecting a Ventcroft Sound Bomb 2 to my panel. The manual says Bell/Strobe has a max supply of 500mA and AUX 300mA. I currently have a bell box connected which I am sure its in SAB mode. I don't know how many milliamps it pulls since I can't find the manual. The Sound Bomb 2 does not say how much milliamps it pulls. Will it be ok to connect the Sound Bomb or will i be drawing too much from the panel?
Thankyou
djrock
The sound bomb pulls 190mA..
Roughly what milliamps would an external bell and strobe take?
Thankyou
djrock
Thankyou
djrock
It will depend on what make the sounder is, the "Ventcroft Classic" would pull
Standby Current 42.3 mA
Current 130 mA Nominal (150 mA Max.)
Single Piezo 125 mA (160mA Max.)
I can't remember the make. I was having a look at the Ventcroft Classic spec to get a rough guide. So
53.3 Constant Led
150 Strobe
300 assuming its Twin Piezo
503.3 Total mA max
I might think about it (when i get a pair of ear plugs) and open the bellbox to see what info i can get from it. Or i was thinking about using a relay and a 12v dc to run the Sound Bomb.
Thankyou
djrock
If I was you, I would just wire it up and try it. If it works ok, Good. If it doesn't, worst it will do is blow a fuse. Chances are, you wont have a problem.
Trade Member
Connect in the sound bomb,
You will be well under the max load your Bell output can handle.
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
So the bellbox which i have and don't know the make/model of with the sound bomb will not exceed 500mA max.
Thankyou
djrock
  djrock said:
How would you know if it
