Accord XPC
Guest Vick
I have an Accord XPC control panel I have installed two pirs using DEOL and door contacts. The pirs which have installed works fine with one back door contact, but I am having problem with the front door contact. As soon as I open the door the system gets in to the temper mode and the keypad sounds. Can you please advice me on right way to wire the front door contact so I can use the alarm system.
Thank you
Vick
