Help with DM4e
Guest london lad
Guest london lad
Hi all,
I have just re-installed a dedicated micros 4e that was taken out of service 2 years ago.
Its all working OK but I am sure when we last used it we were able to set it to switch the main monitor display to show the camera with activity (real time)
Try as I might I cant seem to get it to do this now. The best I have managed is to turn on the buzzer on activity.
It would be much appreciated if any one could point me in the right direction on this on.
Thanks.
I think that this can only be done on alarm inputs rather than activity, and the global alarm input (pin 9 25way dsub) has to be set.
Guest london lad
Hi Breff, You may be right but I am 99.9% sure we had this working last time round and we have never used the alarm inputs at all.
Thanks for trying :)
Guest london lad
Breff, you were right! Thanks all...
