Master Blaster
ADEMCO
Hi, I am running a Texecom Veritas 8 on our house alarm and was wandering if a Master Blaster could be fitted to this control pannel. How would it be wired into the Veritas 8(I know it is only activated by the panel and is powered by 240 volts)
Use your bell trigger to activate the relay on the master blaster.
Is it in your actual house where your going to locate it because you could end up with some dirty linen if it goes off in the night. :ninja:
Master Blaster inside = knackered ear drums
I have 2 on my house one in the garage and 1 under the eaves at the front also have 2 x ts100 //.National Installer.// live bell boxes and an extension speaker inside. Also have a small switcher on to a 10 amp relay to switch all the out side lights X 11 flash on and off in alarm
YOU KNOW WHEN IT GO's OFF... Thats the idea
Also have a smoke screen in the garage but did not connect it as i thaught i was going to far, LOL
Also have cctv
Guest Trulloman
Also have cctv
I bet your popular with your neighbours :ranting:
Is this your house - http://i-am-bored.com/bored_link.cfm?link_id=14019
Guest Trulloman
1 x FA in 6 years and that was a spider
Sack your cleaner :ranting:
Guest Cerberus NI
Also have cctv
They'll still get you,you know.Some day,some time,they'll be there - waiting their chance,biding their time.
THERE IS NO ESCAPE!!!!!!!!!!!!!!!!!!!!!! :ninja:
