New Pir
djrock
Whats the difference between the Rokonet - iWISE
Mr Partridge Would you recommend fitting the iWISE
If installed correctly in compliance with the instructions, and your garage never falls below it's recommended operating temperatures then I see no reason why it shouldn't perform well.
Whats it operating temperature since i can't seem to find it?
thankyou
djrock
iWISE detectors incorporating Anti-Cloak
one gap big enough and long which is the door to allow a car in where they can get in
Fit a Rubber strip along the bottom, or a self adhesive foam one(cheap to replace) both will take up the gap and not stop the door closing.
I don't think the temperatures in my garage will be as low as -20 or as high as 55oc. Where did you find that PDF? Was it in the member
alarmgard thanks for the tip! :)
One other question about the iWISE is will it still be ok if the mice happen to run across shelves? Or will it see them and cause a fa?
thankyou :)
djrock
