Sonic BOOM
Guest Superwidget
Guest Superwidget
Hi
Has anyone ever tried to use acoustic sound to protect a property?
For example, by installing a dozen high intensity 'sound bombs' in every room & passage such that it would be painful to stay inside the property if the alarm was activated (ie, cause pain/bowel evacuation to anyone in the vicinity).
I welcome you comments / suggestions
Regards
Superwidget
ps. any recommendation on the best internal sounder to use for this scheme ?
  • 10 months later...
Guest mike2004
4507[/snapback]
Do you really want your alarm system to cause bowel evacuations? Coming home to a burgled house must be bad enough, but if the floor was covered in poo also......
And how about false alarms. "Ah well, lets get out the disinfectant again...!"
4507[/snapback]
24971[/snapback]
:lol:
Try the inferno from klaxon systems, installed one the other day. you cant tell where the sound is coming from.
Dave Oxendale
York based security systems engineer.
cheers, I read a review a few months ago, but was put off with the price, they do look well though.
They only cost so much because they are built like the chieftain tank
Dave Oxendale
Gardsound 2+ is a good internal sounder, IIRC 120dB.
They certainly make your head ring :wacko:
Hang about a mo
In this do good world you will likly find yourself on the wrong side of the law.
Be carefull
Jef
Customers!
