Wiring The Internal Siren And The Panic Button
Guest Vick
I have Accord XPC control panel and a residential internal SA siren. Can anyone advice me on wiring the internal siren. also I need the wiring help on connecting the double push panic button as I didnot get any instruction on wiring it.
Thank you
Depends on which version of Siren you have and wiring a pa is covered in the engineer manual.
I have internal siren TYCO 675.002.053
Terminal connections as
R-
II+
II-
BAT-
BAT+
RTN
I am using control panel wiring as DEOL
Guest Trulloman
Are you in the trade Vick?
I doubt it as he's struggling with the PA connections. :unsure:
I am not in the trade I am installing the system first time. I have learnt how to wire a PA but i didn't figure out how to wire a internal siren.
Guest Trulloman
R-
II+
II-
BAT-
BAT+
RTN
You say your having trouble wiring siren but you have the information that you have posted telling the connections, just match them to the same connections in the panel excluding the batt + & - of coarse
What about the programming of the zones in all three groups, you may have wired them ok but do they work correctly in each set state. Pa could work in full set but not in part or night if not programmed fully.
