Accenta 8
Guest Taro
We've got an Accenta 8 and it has recently started to make a chirping sound once every 4 mins. There are no smoke alarms in the vincinity - so this can be ruled out! I've checked the user and engineer manuals, but there is no mention of what it means. Any help much appreciated. :rolleyes:
Are you sure that you havn`t enabled a zone with the chime feature..?
Press chime and see if any indicators light up, if so press the corresponding number on the keypad to turn the indicator lights off. Then press RESET .
