Guest Shaks Posted December 3, 2005 Posted December 3, 2005 Hi Just wondering what trigger inputs you would normally connect up from a texecom veritas excel control panel with an 8 channel interface to a texecom speech only dialler with 4 trigger inputs. I am currently using: PA, Intruder and Duress (for duress code no bells) I don't have any fire detectos and have tried the set/unset output but have no need for the panel to ring me when the alarm is set. I am not sure what these do: Abort? - is this to abort dialling? I am currently using abort on reset trigger or by code Zone Lockut? Confirmed - not sure what this is for? I am thinking of using the zone lockout but not sure if there is any need. Apparently it's if any zones remain open at the end of the 2nd intruder time - Is this useful? Any advice would be appreciated. Shaks
Guest Posted December 3, 2005 Posted December 3, 2005 Unless you really need anything else other than notification of an activation then I'd just connect PA, Fire and Intruder. If you're using a duress code then connect that up as well if you want additional information over and above 'the alarm has been activated' messages. I'd also connect the additional wire in for fire as if you ever do add smokes onto the system the trigger is there as it's easier to do now rather than later.
Guest KRISS CROSS Posted December 3, 2005 Posted December 3, 2005 Unless you really need anything else other than notification of an activation then I'd just connect PA, Fire and Intruder. If you're using a duress code then connect that up as well if you want additional information over and above 'the alarm has been activated' messages. I'd also connect the additional wire in for fire as if you ever do add smokes onto the system the trigger is there as it's easier to do now rather than later. I agree with Lurch the duress trig is a nice idea as it is a silent alarm
Zak Posted December 3, 2005 Posted December 3, 2005 I agree with Lurch the duress trig is a nice idea as it is a silent alarm But virtually useless on a non-policed system Zak Tankel - Managing Director - Security First (UK) - www.securityfirst.uk.com Disclaimer: Any comments or opinions expressed by me are my own as a member of the public and not of my employer or Company.
