Optima compact
Guest hoyahammer
Guest hoyahammer
can anyone help The key pad has went dead yet the remote key pad is working ok
allso every now and then the system bleeps as if someone was keying in I have run through the alarm tests every thing checks out .
john
Guest oldtimer
John
I would advise you to disconnect all equipment that uses power from the panel ie PIR SAB RKP and check the operation of the panel. If you still have a problem the crash the panel back to factory settings and if that does not work then
get a new panel.
Guest kenny james
have you got a second keypad fitted?,sounds double dutch what you are saying"the key pad has went dead yet the remote keypad is working o.k(can you describe this in more detail), was it installed by an alarm company if so it sounds like they have activated the service timer.
