Texecom Premier 48 + Tcp/ip Communicator Module
Guest SparksSN
Guest SparksSN
Hi there,
Does anyone have any information about the Texecom Premier 48 + TCP/IP Communicator Module and how it works, how to use it etc.... I install many Texecom Premier alarm systems and upto now I have always used the Com2400 for ARC signalling, it would be nice if I could get the signalls over an ethernet network and then over the internet via an ADSL line so as to reduce the number of telephone lines coming in to the ARC.
Thanks in Advance,
Simon Sparks
P.S. If this is possible will I need new software to recieve the signals and if so which software should I get.
Simon
I would advise you to speak to Mark Heinzelman at Texecom. He is very helpful.... and knows all the Texecom products in great depth.
Chris
