Aritech Ats 2000/3000/4000 Series Control Panel
Guest Just_me
Guest Just_me
Following the protocol given for the above panel, all alarms semm to be reported as faults. I want to aomehow simulate a fault to check the correctness of the protocol, but I dont know how one would do this.
Does anyone know an easy way to simulate a fault?
Do you have proper EOL/DEOL settings..?
:question:
What do you mean by all alarms are reported as faults.
A fault will be reported as a fault and and an alarm will be reported as an alarm.
Tamper a input and see what happens :)
Ps. 1. Are you fitting this panel.
2. Is it your first ATS.
3. Ive fitted about 30 ATS and had two training days with Aritech, and Im still not an expert.
4. Give me some more info and I may be able to put you in the right direction. :)
Top tip: if you ever catch fire, try to avoid seeing yourself in the mirror, because i bet thats what REALLY throws you into a panic and dont forget the one thing you cant recycle is wasted time.
I think you are looking for an "alert" these are NOT faults these are drawing your attention to one of many problems. Try a line fai, or a power fail, or a mask, or fail to set, these go on and on and are causing our engineers a real problem. We dont want them, the customer dosent want them but what can we do the europeans insist we have them.
Jef
Customers!
Jef
Sorry Jef but i didn't get it at all what you tried to say. i thou guess it is forgiveable to me :lol: ...
I was a bit lost when PX34 told me Cct3 FAULT when i tried to set area. me went to pick up screwdriver and open the PIR and i was looking at the tamper lid, resistors and everything seemed to be OK, but still panel told me Cct3 Fault.. WTF??? well the i did RTFM again and voil
  • 11 months later...
Guest paulo pereira
i have read you topic
and i think that you have to adress the central
and you have to see if you have adress right the ras
  • 4 years later...
Hi,
do you know where i can download the Aritech ATS 4000 Series protocol?
Thank you,
Roman.
