Guest spipes Posted December 6, 2005 Posted December 6, 2005 I have a Scantronic 9448 which was fitted before we bought the house and I need to change the entry time. It is currently set to 0 and I need the full 30 seconds. Any ideas? The manual refers to the capability but does not advise on how to configure. Any ideas would be very welcome.
whistle Posted December 6, 2005 Posted December 6, 2005 You cant have 0 entry exit time. It sounds like your fx door contact is sticking and the hall pir is picking you up 1st instead of the door contact. Or your coming in the wrong way. Get an engineer to check over the system.
kka Posted December 6, 2005 Posted December 6, 2005 I have a Scantronic 9448 which was fitted before we bought the house and I need to change the entry time. It is currently set to 0 and I need the full 30 seconds. Any ideas? The manual refers to the capability but does not advise on how to configure. Any ideas would be very welcome. i stand to be corrected, but that may well be programming and as such, information would not be given out in the public section of this forum i stand to be corrected, but that may well be programming and as such, information would not be given out in the public section of this forum just looked, the manual say the minimium set is 10 second. so its looks like a little interesting problem for some alarm engineer. Kevin Scott. Owner of KK Alarms...... Installation .. Service .. Repair ...... Thoughout.. Northumberland and North Tyneside ..... Tel:01670 361948 (call diverted after 15 seconds) or 07947444114
Guest spipes Posted December 7, 2005 Posted December 7, 2005 Thanks Guys - I'll find a local engineer
