Anti Masking Pirs
And there was me thinking they were to detect when wor lass was wearing the green sh*** on her face for bed. :whistle::IDEA::rolleyes:
:1eye:
Having fun with these anti masking detectors. We use optex DX's on castle panels. You'd think now you have 2 ID chips in grade 3 jobs they would have made a bit more room in the bottom of the pir to put your chips and 2 or 3 cables!
Three Full Trips Resets The DT (Or Programmable To 1 Via DIP S/W)
And I Am Told By Galaxy Tech The Anti Mask Reset Should Be Level 7
Yes The Panel Will Set After The DT Has Reset But It Still Shows The Mask Till Level 7 Reset Given
No on both counts, the Dip S/W are they the bank of 8 above the outputs, if so these are for configuring the outputs.
A mask condition causes a Alert which is to inform the customer and does not require a engineer reset, if the panel is requiring a engineer reset for mask, you have either a faulty panel, not programmed it right or put the resistors in wrong and the mask is causing a tamper.
www.nova-security.co.uk
www.nsiapproved.co.uk
  • 5 months later...
i have got to fit 5 intellisense dt900 dual pirs with mircowave and anti mask it it poss to link out the anti mask as i only have 6 core cable runing to them to them but if i use anit mask i need 8 core i can change it the cable as it all built in the wall to use anti mask i will need 8 core (2 for the zone 2 for the temper 2 for ant mask) can any one help me with this
wayne
Wayne Hibbs
wayne
You only need a four core, two for power and two for circuit including anti-mask, I think you might want to consult a installation / engineers manual before you start.
i have read the installation manual but its not very good to use the anit mask do i wire the zone and anti mask in dasy chain format with a reistancer at the end and in the reistancer
wayne
Wayne Hibbs
wayne
i have 5 pir with anti mask do i have to use the anti mask or can i leave it out
wayne
Wayne Hibbs
wayne
I'm guessing you are'nt in the trade. What do you need 5 DT-900s for? And what panel are you connecting them to?
Trade Member
iam conecting them to a texecom premier 48 panel and are using them to cover a large sales area extra large saw mill
Wayne Hibbs
