Newlec Nl5702n
Guest nitestrike
Guest nitestrike
  Cerberus NI said:
Hmmm,put it into to supervisor/access mode by putting in the code then (from memory as Im not standing in front of it) there's a button to go up an access level.Press and hold and it steps up then you press disable until it's at the required zone and change the status.That's not quite it but it's Saturday and I haven't worked on one in near two years!
im not in front of the panel at the mo but once its in superviser mode i can only get it to test or disable diffrent zones, theres 5 buttons on the panel in order 1" sounders on/off 2"mute panel 3"reset 4"advance 5" select. when its in superviser mode the only option i can work out is to hold advance in and that cycles between test and disable
its dosnt give me the option of knocking off the disable,
Guest Cerberus NI
  jb-eye said:
Im out, didnt realise you could issolate a zone on this panel and i dont understand re-arm. If the building is empty and the system is clearly not monitored (because if it was one would assume a maintainer) its about as much use as well its no use until people go back into the building so why worry.
Re-arm as in de-isolate,but yes if it isn't monitored then leaving the detection off until next day isn't going to do any harm (unless.of course,that there is some sort of accomodation connected with the group).
Again,from memory,if you push advance to disable then select to whatever zone is isolated the LED should change staus to show if the zone is disabled or not.
Guest Cerberus NI
  1019641 said:
Manual Added.
MODS:- Delete If Required
Memory not too bad then - in the right ball park!
Whos the original manufacture, cloride? (with an H somewhere)
