Guest the machine Posted December 11, 2005 Posted December 11, 2005 Anyone help me on this one. I have used all inputs on the ID loop (1 - 30 ) but wish to add another detector. Can I use CCT31 & cct32 ? if so do i use the aux tamp input on the board? cct 31 and 32 currently read tamper (with aux tamp linked out ) cant find anything in user manual that mentions cct31, 32 or even how to use the aux tamp input. thanks guys john
Guest the machine Posted December 11, 2005 Posted December 11, 2005 thank you for your reply. i thinkt theres plenty of power, mainly velux windows im covering. well i have 2 id inputs spare as i blew the biscuits (8 and 19) bought a whole new set of 1-10 biscuit and blew number again !!!!! ill try power down next time ! (anyone wanna trade bickies ???) i need 8 and 19. ok, i can get into engineers as i have the manual, i see 31 and 32 there and i set them as chime circuits for now, but i dont know where to connect the wires on the pcb as theres no spare connections, unless i use the digicom but i thought that was output only ( i have connected digicom 1 , 2 and 3 to my speech dialler) maybe i could just bight the id bullet , er biscuit and buy some more !!! namely 1-10 and 10 - 20 !! bang goes another
Guest the machine Posted December 11, 2005 Posted December 11, 2005 Thank you for your help. It makes sense the inputs being in Keypad. Ill have to get the biscuits i think. the system is ok, i was just expanding the set up with some extra smoke detectors. if you can reccommend an installer in my area ill mention your company when dealing , as I intend to have more systems fitted. I was basically trialing this technology out. I am in SOUTHPORT Lancashire John
Guest 9651 Posted December 15, 2005 Posted December 15, 2005 ccts 31 and 32 don't reqiure buiscuits, they are wired up using the double pole method.... or with EOL resistors.....
