Accent Minig3
Guest APE
Hi all , started fitting these panels and got me first prob ,the sounder wont work .Everything else is fine ,it operates in tamper when lid removed ,tried swapping sounder ,still same .So think its the hold off relay on the board ,but wondered if it could be anything else ie programming etc
cheers APE :hmm:
Have you accidentally programmed a bell delay ?
Does it work instantly from the Eng or User Test menu's?
ARJ
A nearly retired previous installer !
That would imply that you are an 'installer' of some sort?
If so, test for voltages in the right places on the SAB connections on the panel. If all is correct then either you're cabling is incorrectly terminated, damaged or your meter's u\s.
Yes of some sort ,dont do many installs thou .It doesnt work in test mode in engineers either havent tested voltage as i pressumed the panel was at fault ,as it works in tamp mode.Just thought could be summat simple.
Thanx APE
Thanx APE
Have you tried moving the Bell trigger accross in the panel to a definite neg ( i.e. Aux - ) and see if it fires off immediately.
- If it doesn't, you know that theres a bell or wiring fault.
- If it does, you know that the bells fine but panel isn't giving a switched neg to the trigger output
Try metering the bell output and see if it gives you a neg when you run the Bell test
(Red probe to Bell+(D) , Black probe to Bell -(B) ) you should see 12-13v when bell is active (or should be), 0v when innactive.
ARJ
Yes of some sort
'Nuff said. :whistle:
It doesnt work in test mode in engineers either. havent tested voltage as i pressumed the panel was at fault ,as it works in tamp mode.Just thought could be summat simple.
"Assumption is the mother of all f*ck ups".
As you haven't bothered to test anything and expect us to tell you what's wrong I don't see any point in carrying on with this.
Have you a problem ?? this is a forum is it not ?? if you havent anything good to say then ********
suprised you get anyone on here with your attitude
Thanx ARJ
