Good Pir For Use In A Garage?
andyhodson
  Alarm Guard said:
Alternatively, buy a new garage! :yes:
Or a bag of sand and cement and a box of silicone. ;)
A box of silicone :hmm: Assume you mean, say, 12 tubes :yes:
I get what that is for...but the cement - im lost :cry:
Email : martin@askthetrades.co.uk
Yup. :)
The really large holes. ;)
Guest security.eng
napco or rokonet are good dt makes, they work in extreme temps, but remember to seal all entry holes. :rolleyes:
  • 4 weeks later...
Guest Alarm Guard
  securitcctv said:
What affect do draughts have on a pir sensor?
They see the area as just a collection of hot, cold & warm areas or objects. If a block of air can blow into the room the heat pattern would be altered enough to trigger the sensor
  • 2 weeks later...
  Eng said:
a good pir will work as well as any dt in a a garage..why oh why do people see dt's as the answer to everthing....ive got a ir 220 in my garage with no probs...remember dt's false alarm everyday it not what you fit its where you fit it...id choose a good pir over a average dt anyday..
But it also depends on the environment of the garage. Every garage is different.
Everyone has there own opinion.
Maybe i was a bit strong in saying Standard pirs are useless in a garage environment.
djrock
