Premier Com2400
Guest elvis123
Thanks, yes I have got the NTE socket. Just thought I can eliminate that box by plugging the BT cable directly into the Com2400. And re-use the box in parallel with the rest of the extensions. Otherwise, I'll have to run a cable from the NTE socket to the Com2400 via the filter, then run another cable from the Com2400 to a new BT box and then connect that to the rest of the extensions. But I am happy to run it this way, a few extra wires no problem.
Now I see what you're doing. :) Seems to be along the right lines there.
