Guest Tim L Posted December 13, 2005 Posted December 13, 2005 I have inherited a Citadel XR2 domestic house alarm. The control panel has locked out following a lengthy power cut. I have tried shutting the power off but this just allows me to reset imputting key code then it locks out again. Alarm panel shows power light and attack? Can anyone help please?
Guest Posted December 13, 2005 Posted December 13, 2005 Is there a panic button somewhere that's been activated? If you have buttons double check and make sure they hae been reset.
Guest Tim L Posted December 13, 2005 Posted December 13, 2005 I have inherited a Citadel XR2 domestic house alarm. The control panel has locked out following a lengthy power cut. I have tried shutting the power off but this just allows me to reset imputting key code then it locks out again.Alarm panel shows power light and attack? Can anyone help please?
Guest Tim L Posted December 13, 2005 Posted December 13, 2005 Is there a panic button somewhere that's been activated? If you have buttons double check and make sure they hae been reset. There are no panic buttons in the house. There is a panic feature on the control panel when 9 and 4 is pressed together.
Guest Posted December 13, 2005 Posted December 13, 2005 There is a panic feature on the control panel when 9 and 4 is pressed together. If that was activated it should be reset by either inputting the code again or pressing reset, which generally clears most things. If everything is as it should be from your point of view, then I would recommend getting the system loked at by an engineer.
Guest Tim L Posted December 14, 2005 Posted December 14, 2005 Looks like I need an engineer. thanks for help all -
j.paul Posted December 14, 2005 Posted December 14, 2005 I have inherited a Citadel XR2 domestic house alarm. The control panel has locked out following a lengthy power cut. I have tried shutting the power off but this just allows me to reset imputting key code then it locks out again.Alarm panel shows power light and attack? Can anyone help please? Sounds like the panel has locked up after "lengthy power cut" The system will need powered down, then powered back up.. But I would get the battery checked as well. Looks like I need an engineer. Recommended There are no stupid questions, but there are a LOT of inquisitive idiots.
