Accenta 8 Problems From Power Failure
Guest Vince Hawkes
Guest Vince Hawkes
Hi, Can you help,
Moved into new house with a Accenta 8 alrm system. The house has been empty for 9 months with the mains off. Turned on mains alarm went off, put in the code given to us, would not stop. Called installer, they've gone bust. In the end I took the fuse out. I was told it was probably due to battery being flat as mains off for so long. Bought new battery no sooner do I connect it but the alarm activates and does not stop when code is entered. I don't have an operating manual so don't know if I'm doing it all wrong or whether there's a fault... please help
I'm in Harlow in Essex. I tried the 0123 code as well but didn't seem to work unless I'm doing something wrong when entering it
