Mixing Eol And Double Pole Of Texecom Premier
Guest heliart
Guest heliart
I know you can mix double pole and EOL wiring on each zone on a Texecom Premier. Is this configured purely on the wiring of the zone, as there does not appear to be any zone setting that determines this.
If its a premier 48 just wire the zones it don't matterr.
If its a 24 i don't think you can mix on the endstation but feel free to on nodes or rkp's.
Guest heliart
It's an Premier 88. Thanks for the feedback.
The panel auto detects by the way the zone is wired.
Im sure you are aware, but, dont mix eol and double pole on the same zone, ie 2 devices.
Guest heliart
Thanks for the advice.
As I've wired all this from scratch, I have one zone for every sensor, no sharing.
Thanks.
Steve
